pcf8563_rtc_read_time
- Syntax:
static int pcf8563_rtc_read_time(struct device *dev, struct rtc_time *tm)
- Description: The function is used to read RTC time information from AT8563 RTC devices.
- Parameter:
- dev: The target RTC device.
- tem: The location where RTC time information is stored.
- Return:
- Success: 0.
- Failure: Error code.
