Using Xmodem
After the hardware connections mentioned above, power on the VisionFive and you will see the
startup information as follows.
Figure 1. Example
Press any key as soon as it starts up to enter the upgrade menu.
In this menu, you can only update u-boot.
Figure 2. Example
Type root@s5t and press Enter to enter
the extended version of the upgrade menu, and in this menu, you can update u-boot,
bootloader, and ddr init.
Figure 3. Example
- Type 0 and press Enter to update the bootloader.
- Press Ctrl+A and then press S to enter upload mode.
Select xmodem and press Enter.
Figure 4. Example
Select Goto from the bottom tab menu and press
Enter.
Figure 5. Example
Enter the directory path and press Enter.
Figure 6. Example
Select
bootloader-JH7100-211102.bin.outby navigating using arrow keys, press Space and press Enter. -
