Debugging UART Send and Receive Functions
Configure VisionFive
2
Minicom:
sudo minicom -s -
Select Serial port setup, and configure Minicom as follows:
Figure 1. Example Configuration
Start VisionFive
2 minicom by
typing the following command on the PC:
minicom -o -D /dev/ttyS1Figure 2. Example Output
Configure Ubuntu minicom by typing the following:
sudo minicom -s -
Select Serial port setup, and configure minicom as follows:
Figure 3. Example Configuration
Note:Serial Device can be detected by command
dmesg | grep ttyon UbuntuFigure 4. Example Command and Output
Start Ubuntu minicom, you can see as follows:
Figure 5. Example Output
Test UART Send:
To test UART send function, you can input characters, such as
hello ubuntu, on the VisionFive 2 minicom. Then you will see the character are outputted on the Ubuntu minicom as the following:Figure 6. Test UART Send
Figure on the Left: Ubuntu minicom interface
Figure on the Right: VisionFive 2 minicom interface
Test UART Receive:
To test UART receive, you can input characters, such as
hello visionfiveon the Ubuntu minicom. Then you will see the characters are outputted on the VisionFive 2 minicom:Figure 7. Test UART Receive
