Testing SPI with ADXL345 Module
Perform the following steps to test SPI with the ADXL345 module:
Connect the ADXL345 module to the 40-pin header as the following:
Figure 1. Connect ADXL345 Module to the Header -
Locate to the following path for test tool, spidev_test.c:
cd /linux/tools/spi -
Execute the following command under the test tool directory:
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscvResult:The output file is spidev_test in the same directory.
Upload spidev_test to VisionFive
2, and change the execution
permission by executing the following:
chmod +x spidev_test -
Confirm the SPI device.
ls /dev/spidev*Figure 2. Example Output
In this output, spidev1.0 is the device name.
Execute the following to read the device ID:
./spidev_test -H -O -D /dev/spidev1.0 -v -p \\x80\\x00 -
Execute the following to read the value for multiple registers:
./spidev_test -H -O -D /dev/spidev1.0 -v -p \\xec\\x00\\x00\\x00\\x00\\x00\\x00 -
Execute the following to read:
./spidev_test -H -O -D /dev/spidev1.0 -v -p \\x9e\\x00 -
Execute the following to write:
./spidev_test -H -O -D /dev/spidev1.0 -v -p \\x1e\\xaa -
Execute the following to read the verification:
