Basic Configuration
  1. Execute the following command to enter the menu configuration GUI:
    make menuconfig
    In the menu configuration GUI, follow the steps to select the corresponding option:
    1. In OpenWrt Configuration, select Target System and Target Profile:
      • Target System (StarFive JH71x0 (7100/7110))
      • Target Profile (StarFive VisionFive 2 v1.2a) or Target Profile (StarFive VisionFive 2 v1.3b)
        Note: VisionFive 2 currently has 2 versions, v1.2a and v1.3b. Please select the appropriate submenu according to the actual version.
        Figure 1. Profile Configuration
    2. In OpenWrt Configuration, select ramdisk under Target Image:
      Figure 2. Target Images
  2. Luci configuration
    1. Execute the following command to install luci:
      ./scripts/feeds update packages luci
      ./scripts/feeds install -a -p luci
    2. Execute the following command to enter the menu configuration GUI to configure luci:
      make menuconfig
    3. Select uhttpd in the configuration menu bar in the following order:
      Network > Web Servers/Proxies > uhttpd
      Figure 3. uhttpd
    4. Select luci in the configuration menu bar in the following order:
      • Select luci in the configuration menu bar in the following order:
        LuCI > 1. Collections > luci
        Figure 4. luci
      • (Optional) Select the language according to your requirement in the configuration menu bar in the following order (take Chinese Simplified as example):
        LuCI > 2. Modules > Translations > Chinese Simplified (zh_Hans)
        Figure 5. Chinese Simplified (zh_Hans)
      • Select luci-app-ddns, luci-app-firewall, luci-app-samba4, luci-app-uhttpd in the configuration menu bar in the following order:
        LuCI > 3. Applications > luci-app-ddns, luci-app-firewall, luci-app-samba4, luci-app-uhttpd
        Figure 6. Applications
      • Select all in the configuration menu bar in the following order:
        LuCI > 4. Themes > Select all
        Figure 7. Themes
      • Select luci-lib-ipkg in the configuration menu bar in the following order:
        LuCI > 6. Libraries > luci-lib-ipkg
        Figure 8. Libraries Configuration
