Extend Partition on SD Card or eMMC
To fully utilize the unused space on the SD card or eMMC after logging into Debian, perform the following steps:
- Use the following command to list available
elements:
~# df -hExample Output:
Filesystem Size Used Avail Use% Mounted on udev 3.7G 0 3.7G 0% /dev tmpfs 793M 3.1M 790M 1% /run /dev/mmcblk1p4 2.0G 1.9G 88M 96% / tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs 793M 32K 793M 1% /run/user/107 tmpfs 793M 24K 793M 1% /run/user/0 Run the
Example Command:fdiskcommand with disk name as an argument.root@starfive:~# fdisk /dev/mmcblk<X>Tip: <X>: The application value is 0 or 1. 1 for SD card and 0 for eMMC.Example Output:root@starfive:~# fdisk /dev/mmcblk1 Welcome to fdisk (util-linux 2.38.1). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. GPT PMBR size mismatch (4505599 != 62929919) will be corrected by write. This disk is currently in use - repartitioning is probably a bad idea. It's recommended to umount all file systems, and swapoff all swap partitions on this disk. Command (m for help): d Partition number (1-4, default 4): 4 Partition 4 has been deleted. Command (m for help): n Partition number (4-128, default 4): 4 First sector (34-62929886, default 221184): Last sector, +/-sectors or +/-size{K,M,G,T,P} (221184-62929886, default 62928895): Created a new partition 4 of type 'Linux filesystem' and of size 29.9 GiB. Partition #4 contains a ext4 signature. Do you want to remove the signature? [Y]es/[N]o: N Command (m for help): w The partition table has been altered. Syncing disks.- Resize the /dev/mmcblk<X>p4 partition by running the
resize2fscommand to fully utilize the unused block.Tip: <X>: The application value is 0 or 1. 1 for SD card and 0 for eMMC.Example Command and Output:
root@starfive:~# resize2fs /dev/mmcblk1p4 resize2fs 1.46.6-rc1 (12-Sep-2022) Filesystem at /d[ 295.372617] EXT4-fs (mmcblk1p4): resizing filesystem from 535291 to 7838464 blocks ev/mmcblk1p4 is mounted on /; on-line resizing required old_desc_blocks = 1, new_desc_blocks = 4 [ 295.993163] EXT4-fs (mmcblk1p4): resized filesystem to 7838464 The filesystem on /dev/mmcblk1p4 is now 7838464 (4k) blocks long.Verification:
Rundf -hto verify the new size of partition, and to verify that our steps to extend partition (/dev/mmcblk<X>p4) are successful.Tip: <X>: The application value is 0 or 1. 1 for SD card and 0 for eMMC.The following output indicates the modification is successful:
root@starfive:~# df -h Filesystem Size Used Avail Use% Mounted on udev 3.7G 0 3.7G 0% /dev tmpfs 793M 3.1M 790M 1% /run /dev/mmcblk1p4 30G 1.9G 28G 7% / tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs 793M 32K 793M 1% /run/user/107 tmpfs 793M 24K 793M 1% /run/user/0
