Logging into Debian
Perform the following steps to log into Debian:
- Connect a display to VisionFive 2 via HDMI.
- Set the boot mode as required. For instructions, see VisionFive 2 Boot Mode Settings.Tip: StarFive recommends that you use SD card or eMMC mode since the versions of SPL and U-Boot in the QSPI flash may be outdated and require update. If you need to update SPL and U-Boot, refer to Updating SPL and U-Boot.
- Insert the TF card with the Debian image into VisionFive 2 and power it on.
- Enter the credentials as follows:
- Username: user
- Password: starfive
- You can log into Debian OS by:
Tip: If you need to load different DTB files, update the
./boot/uEnv.txt file as described in the Step 6 under
Adding New File section in the VisionFive
2 Single Board
Computer Software Technical Reference Manual.
