Connect VisionFive 2 to Network
This section provides steps to connect VisionFive 2 to network and enter U-Boot terminal.
Connect the jumper wires between the USB-to-Serial converter and the Debug pins of VisionFive 2 40-pin GPIO header. The following figure is an example:
Figure 1. Connecting to the Debug Pins of VisionFive 2 40-pin GPIO Header - Configure the serial port baud rate settings to 115200 bps.
- Connect VisionFive 2 to the network cable and power cord.
- Turn on VisionFive 2 and you
will see the start-up information as
follows:
U-Boot SPL 2021.10 (Oct 31 2022 - 12:11:37 +0800) DDR version: dc2e84f0. Trying to boot from SPI OpenSBI v1.0 ____ _____ ____ _____ / __ \ / ____| _ \_ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ \___ \| _ < | | | |__| | |_) | __/ | | |____) | |_) || |_ \____/| .__/ \___|_| |_|_____/|____/_____| | | |_| Platform Name : StarFive VisionFive V2 Platform Features : medeleg Platform HART Count : 5 Platform IPI Device : aclint-mswi Platform Timer Device : aclint-mtimer @ 4000000Hz Platform Console Device : uart8250 Platform HSM Device : --- Platform Reboot Device : --- Platform Shutdown Device : --- Firmware Base : 0x40000000 Firmware Size : 360 KB Runtime SBI Version : 0.3 Domain0 Name : root Domain0 Boot HART : 3 Domain0 HARTs : 0*,1*,2*,3*,4* Domain0 Region00 : 0x0000000002000000-0x000000000200ffff (I) Domain0 Region01 : 0x0000000040000000-0x000000004007ffff () Domain0 Region02 : 0x0000000000000000-0xffffffffffffffff (R,W,X) Domain0 Next Address : 0x0000000040200000 Domain0 Next Arg1 : 0x0000000042200000 Domain0 Next Mode : S-mode Domain0 SysReset : yes Boot HART ID : 3 Boot HART Domain : root Boot HART Priv Version : v1.11 Boot HART Base ISA : rv64imafdcbx Boot HART ISA Extensions : none Boot HART PMP Count : 8 Boot HART PMP Granularity : 4096 Boot HART PMP Address Bits: 34 Boot HART MHPM Count : 2 Boot HART MIDELEG : 0x0000000000000222 Boot HART MEDELEG : 0x000000000000b109 U-Boot 2021.10 (Oct 31 2022 - 12:11:37 +0800), Build: jenkins-VF2_515_Branch_SDK_Release-10 CPU: rv64imacu Model: StarFive VisionFive V2 DRAM: 8 GiB MMC: sdio0@16010000: 0, sdio1@16020000: 1 Loading Environment from SPIFlash... SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment StarFive EEPROM format v2 --------EEPROM INFO-------- Vendor : StarFive Technology Co., Ltd. Product full SN: VF7110A1-2243-D008E000-00000001 data version: 0x2 PCB revision: 0xa1 BOM revision: A Ethernet MAC0 address: 6c:cf:39:00:14:5b Ethernet MAC1 address: 6c:cf:39:00:14:5c --------EEPROM INFO-------- In: serial@10000000 Out: serial@10000000 Err: serial@10000000 Model: StarFive VisionFive V2 Net: eth0: ethernet@16030000, eth1: ethernet@16040000 switch to partitions #0, OK mmc1 is current device found device 1 bootmode flash device 1 Failed to load 'uEnv.txt' Can't set block device Hit any key to stop autoboot: 0 StarFive # - Press any key to stop and enter U-Boot terminal.
