Pinout Diagram
The following is the pinout diagram:
Note:
- Each GPIO pin can safely draw a maximum current of 32 mA, whereas the maximum current draw when all GPIOs are combined should be less than 100 mA. Please take this into account or otherwise, you will end up destroying the GPIO pins.
- All GPIOs can be configured to support different functions including but not limited to SDIO, Audio, SPI, I2C, UART, and PWM. Since VisionFive 2 Lite uses the same GPIO header as VisionFive 2, refer to the VisionFive 2 40-Pin GPIO Header User Guide for GPIO configuration.
