Run the Default DTB with image.fit
This section provides steps to transfer image.fit through TFTP and run image.fit with the default DTB: jh7110-visionfivev2.dtb.
- Run the following command to set environment
parameters:
setenv ipaddr 192.168.xxx.xxx; setenv serverip 192.168.xxx.xxx; - Upload the image file to
ddr:
tftpboot ${loadaddr} image.fit; - Load and execute the file by
running:
bootm start ${loadaddr};bootm loados ${loadaddr};run chipa_set_linux;run cpu_vol_set; booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r}; - Login with the following
credentials:
buildroot login:root Password: starfiveResult:
The launch is successful!Important: The command above only supports version equal to or later than VF2_v3.4.5. If your SDK version is VF2_v3.1.5 or earlier, please perform the following command:- Run the following command to set environment
parameters:
setenv bootfile vmlinuz; setenv fileaddr a0000000; setenv fdtcontroladdr 0xffffffffffffffff; setenv ipaddr 192.168.xxx.xxx; setenv serverip 192.168.xxx.xxx;
ddr:
tftpboot ${fileaddr} ${serverip}:image.fit; - Load and execute the file by
running:
bootm start ${fileaddr};bootm loados ${fileaddr};run chipa_set_linux;run cpu_vol_set;booti 0x40200000 0x46100000:${filesize} 0x46000000 - Login with the following
credentials:
parameters:
