STFLIB_ISP_DEVICE_DRM_ConvertV4l2FormatToDrmFormat
Convert the V4L2 pixel format to DRM device pixel format.
STFLIB_ISP_DEVICE_DRM_ConvertV4l2FormatToDrmFormat(
    STF_U32 u32V4l2Format
The API has the following parameter.
Table 1. STFLIB_ISP_DEVICE_DRM_ConvertV4l2FormatToDrmFormat Parameter Description
u32V4l2Format V4L2 pixel format Input
Table 2. STFLIB_ISP_DEVICE_DRM_ConvertV4l2FormatToDrmFormat Return Description
Return Description
STF_U32 DRM device pixel format
