STFLIB_ISP_DEVICE_StructInitializeWithDeviceName
Device structure initialization function with device name.
STFLIB_ISP_DEVICE_StructInitializeWithDeviceName(
    ST_CI_DEVICE *pstDevice,
    STF_CHAR *pszDeviceName,
    STF_BOOL8 bForceGenDev,
    EN_MEM_TYPE enMemType,
    STF_U16 u16Width,
    STF_U16 u16Height
Table 1. STFLIB_ISP_DEVICE_StructInitializeWithDeviceName Parameter Description
pstDevice Device handle Input
pszDeviceName Device name Input
bForceGenDev Indicate whether to open the video device using the “fopen” function Input
enMemType Video buffer type Input
u16Width Image width Input
u16Height Image height Input
Table 2. STFLIB_ISP_DEVICE_StructInitializeWithDeviceName Return Description
Return Description
0 Success
Other values Failure
