STFLIB_ISP_DEVICE_FB_ConvertV4l2FormatToFbFormat
Convert the V4L2 pixel format to Frame buffer pixel format.
STFLIB_ISP_DEVICE_FB_ConvertV4l2FormatToFbFormat(
    STF_U32 u32V4l2Format
Table 1. STFLIB_ISP_DEVICE_FB_ConvertV4l2FormatToFbFormat Parameter Description
u32V4l2Format V4L2 pixel format Input
Table 2. STFLIB_ISP_DEVICE_FB_ConvertV4l2FormatToFbFormat Return Description
Return Description
STF_U32 Frame buffer pixel format
