STFLIB_ISP_DEVICE_StructInitialize_2
Device structure initialization function.
STFLIB_ISP_DEVICE_StructInitialize_2(
    ST_CI_DEVICE *pstDevice,
    EN_DEV_ID enDevId,
    STF_BOOL8 bForceGenDev,
    EN_MEM_TYPE enMemType,
    STF_U16 u16Width,
    STF_U16 u16Height,
    ST_RECT_2 stCropRect,
    STF_U8 u8Fps
Table 1. STFLIB_ISP_DEVICE_StructInitialize_2 Parameter Description
pstDevice Device handle Input
enDevId Device ID Input
bForceGenDev Indicate whether to open the video device using the “fopen” function Input
enMemType Video buffer type Input
u16Width Image width Input
u16Height Image height Input
stCropRect Cropping window information Input
u8Fps Frame rate per second Input
Table 2. STFLIB_ISP_DEVICE_StructInitialize_2 Return Description
Return Description
0 Success
Other values Failure
