STFLIB_ISP_DEVICE_StructUninitialize
Device structure de-initialization function.
STFLIB_ISP_DEVICE_StructUninitialize(
    ST_CI_DEVICE *pstDevice,
The API has the following parameter.
Table 1. STFLIB_ISP_DEVICE_StructUninitialize Parameter Description
pstDevice Device handle Input
Table 2. STFLIB_ISP_DEVICE_StructUninitialize Return Description
Return Description
0 Success
Other values Failure
