STFLIB_ISP_DEVICE_GenerateDeviceTable
Generate the media device table.
STFLIB_ISP_DEVICE_GenerateDeviceTable(
    STF_CHAR *pszDriverName,
    STF_CHAR *pszModelName
Table 1. STFLIB_ISP_DEVICE_GenerateDeviceTable Parameter Description
pszDriverName Driver name of media device Input
pszModelName Model name of media device Input
Table 2. STFLIB_ISP_DEVICE_GenerateDeviceTable Return Description
Return Description
0 Success
Other values Failure
