Basic Device
The following code block shows the data structure for the basic device structure.
typedef struct _ST_CI_DEVICE {
    CI_CONNECTION *pstCiConnection;
    STF_U8 u8DeviceId;
    STF_U8 u8DeviceType;
    STF_CHAR szDeviceName[DEV_NAME_LEN_MAX];
    STF_S32 s32CiConnections;
    STF_BOOL8 bConnected;
    EN_MEM_TYPE enMemType;
    STF_VOID *pvDevParam;
    STF_RESULT (*Destroy)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*Connection)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*Disconnect)(ST_CI_DEVICE *pstDevice);
    STF_BOOL8 (*IsConnected)(ST_CI_DEVICE *pstDevice);
    STF_S32 (*GetConnections)(ST_CI_DEVICE *pstDevice);
    CI_CONNECTION *(*GetConnection)(ST_CI_DEVICE *pstDevice);
    int (*GetFileHandle)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*SubscribeEvent)(ST_CI_DEVICE *pstDevice, STF_S32 s32EventType);
    STF_RESULT (*UnsubscribeEvent)(ST_CI_DEVICE *pstDevice, STF_S32 s32EventType);
    STF_RESULT (*DequeueEvent)(ST_CI_DEVICE *pstDevice, struct v4l2_event *pstEvent);
    STF_RESULT (*InitDevice)(ST_CI_DEVICE *pstDevice, STF_U32 u32PixelFormat);
    STF_U32 (*GetPixelFormat)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*SetPixelFormat)(ST_CI_DEVICE *pstDevice, STF_U32 u32PixelFormat);
    struct v4l2_rect (*QueryCropWin)(ST_CI_DEVICE *pstDevice);
    ST_RECT (*QueryCropWin_2)(ST_CI_DEVICE *pstDevice);
    struct v4l2_rect (*GetCropWin)(ST_CI_DEVICE *pstDevice);
    ST_RECT (*GetCropWin_2)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*SetCropWin)(ST_CI_DEVICE *pstDevice, struct v4l2_rect *pstRect);
    STF_RESULT (*SetCropWin_2)(ST_CI_DEVICE *pstDevice, ST_RECT *pstRect);
    STF_RESULT (*EnumFormat)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*GetFormat)(ST_CI_DEVICE *pstDevice, struct v4l2_format *pstFormat);
    STF_RESULT (*SetFormat)(ST_CI_DEVICE *pstDevice, STF_U16 u16Width, STF_U16 u16Height, STF_U32 u32PixelFormat);
    STF_RESULT (*TryFormat)(ST_CI_DEVICE *pstDevice, STF_U32 u32PixelFormat);
    STF_RESULT (*GetParam)(ST_CI_DEVICE *pstDevice, STF_U32 *pu32Numerator, STF_U32 *pu32Denominator);
    STF_RESULT (*SetParam)(ST_CI_DEVICE *pstDevice, STF_U32 u32Numerator, STF_U32 u32Denominator);
    STF_RESULT (*SetParam_2)(ST_CI_DEVICE *pstDevice, STF_U32 u32FPS);
    struct v4l2_rect (*GetSelection)(ST_CI_DEVICE *pstDevice);
    ST_RECT (*GetSelection_2)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*SetSelection)(ST_CI_DEVICE *pstDevice, struct v4l2_rect *pstRect);
    STF_RESULT (*SetSelection_2)(ST_CI_DEVICE *pstDevice, ST_RECT *pstRect);
    STF_RESULT (*SetStreamOn)(ST_CI_DEVICE *pstDevice, STF_BOOL8 bOn);
    STF_BOOL8 (*IsStreamOn)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*AllocateBuf)(ST_CI_DEVICE *pstDevice, STF_U32 u32Count, STF_BOOL8 bMmap, STF_BOOL8 bExport, ST_DMA_BUF_INFO *pstDmaBufInfo);
    STF_RESULT (*AllocateAndEnqueueBuf)(ST_CI_DEVICE *pstDevice, STF_U32 u32AllocateCount, STF_U32 u32EnqueueCount, STF_BOOL8 bMmap, STF_BOOL8 bExport, ST_DMA_BUF_INFO *pstDmaBufInfo);
    ST_VDO_MEM *(*GetBuffer)(ST_CI_DEVICE *pstDevice, STF_U32 u32Index);
    ST_VDO_BUF (*GetBufInfo)(ST_CI_DEVICE *pstDevice, STF_U32 u32Index);
    STF_RESULT (*EnqueueBuf)(ST_CI_DEVICE *pstDevice, STF_U8 u8BufIdx);
    STF_RESULT (*EnqueueBuf_2)(ST_CI_DEVICE *pstDevice, STF_U32 u32Count, ST_VDO_BUF_INFO *pstVideoBufferInfo);
    STF_RESULT (*EnqueueBufFromAvailableQueue)(ST_CI_DEVICE *pstDevice, STF_S32 s32Count);
    STF_RESULT (*EnqueueBufFromCompletedQueue)(ST_CI_DEVICE *pstDevice, STF_S32 s32Count);
    STF_RESULT (*DequeueBuf)(ST_CI_DEVICE *pstDevice, ST_VDO_MEM **ppstVdoMem);
    STF_RESULT (*DequeueBuf_2)(ST_CI_DEVICE *pstDevice, STF_S32 *ps32Count, ST_VDO_BUF_INFO *pstVideoBufferInfo);
    STF_RESULT (*DequeueBufToCompletedQueue)(ST_CI_DEVICE *pstDevice, STF_S32 s32Count);
    STF_RESULT (*SwitchBufFromCompletedToAvailableQueue)(ST_CI_DEVICE *pstDevice, STF_S32 s32RemainCount);
    STF_RESULT (*PushBufToQueue)(ST_CI_DEVICE *pstDevice, sLinkedList_T *pstListQueue, ST_VDO_MEM *pstVdoMem, STF_BOOL8 bIsPushToFront);
    ST_VDO_MEM *(*PopBufFromQueue)(ST_CI_DEVICE *pstDevice, sLinkedList_T *pstListQueue, STF_BOOL8 bIsPopFromBack);
    STF_RESULT (*ReleaseBuf)(ST_CI_DEVICE *pstDevice);
    STF_RESULT (*GenerateLinksInfo)(ST_CI_DEVICE *pstDevice, EN_SNSR_IF enSensorInterface, ST_ITEM_INFO *pstLinksInfo);
    STF_RESULT (*ProcessLinks)(ST_CI_DEVICE *pstDevice, ST_ITEM_INFO *pstLinksInfo);
    STF_RESULT (*ProcessLinks_2)(ST_CI_DEVICE *pstDevice, EN_SNSR_IF enSensorInterface);
} ST_CI_DEVICE, *PST_CI_DEVICE;
Table 1. Basic Device Field Description
Field Description
pstCiConnection The connection handle
u8DeviceId The device ID
u8DeviceType The device type (FB, PP, DRM, Video, V4L2 sub-device, etc.)
szDeviceName The device name
s32CiConnections Indicate the number of applications using this connection handle
bConnected Indicate whether the connection handle is open
enMemType Indicate which video buffer type (EN_MEM_TYPE_MMAP or EN_MEM_TYPE_DMA) will be allocated
pvDevParam Point to the device parameters structure
*Destroy Destroy this device
*Connection Connect to the device driver
*Disconnect Disconnect form the device driver
*IsConnected Check the connection status
*GetConnections Get the number of connections
*GetConnection Get the connection handle
*GetFileHandle Get the file descriptor from the connection handle
*SubscribeEvent1 Subscribe an event to the video device
*UnsubscribeEvent1 Unsubscribe an event to the video device
*DequeueEvent1 Dequeue an event from the video device
*InitDevice Device initialization
*GetPixelFormat Get the pixel format from the device
*SetPixelFormat Set the pixel format to the device
*QueryCropWin1 Query the cropping window from the video device
*QueryCropWin_21 Query the cropping window from the video device
*GetCropWin1 Get the cropping window from the video device
*GetCropWin_21 Get the cropping window from the video device
*SetCropWin1 Set the cropping window into the video device
*SetCropWin_21 Set the cropping window into the video device
*EnumFormat1 Enumerate supported formats from the video device
*GetFormat1 Get the data format from the video device
*SetFormat1 Set the data format into the video device
*TryFormat1 Test if the video device supports this data format
*GetParam1 Get streaming parameters from the video device
*SetParam1 Set streaming parameters into the video device
*SetParam_21 Set streaming parameters into the video device
*GetSelection1 Get selection rectangle from the video device
*GetSelection_21 Get selection rectangle from the video device
*SetSelection1 Set selection rectangle into the video device
*SetSelection_21 Set selection rectangle into the video device
*SetStreamOn1 Start/Stop video device streaming I/O
*IsStreamOn1 Check the streaming I/O status from the video device
*AllocateBuf2 Allocate buffers for the device
*AllocateAndEnqueueBuf1 Allocate and enqueue buffers into the video device
*GetBuffer1 Get the video buffer from the video device
*GetBufInfo1 Get the video buffer information from the video device
*EnqueueBuf1 Enqueue buffer into the video device
*EnqueueBuf_21 Enqueue buffers into the video device
*EnqueueBufFromAvailableQueue1 Enqueue buffers from available queue to the video device
*EnqueueBufFromCompletedQueue1 Enqueue buffers from completed queue to the video device
*DequeueBuf1 Dequeue buffers from the video device
*DequeueBuf_21 Dequeue buffers from the video device
*DequeueBufToCompletedQueue1 Dequeue buffers from the video device to completed queue
*SwitchBufFromCompletedToAvailableQueue1 Switch buffers from the completed queue to available queue
*PushBufToQueue1 Push buffer into the queue
*PopBufFromQueue1 Pop buffer from the queue
*ReleaseBuf2 Release buffers from the device
*GenerateLinksInfo1 Generate the media link information
*ProcessLinks1 Process the media link settings
*ProcessLinks_21 Process the media link settings
Note:
  1. The field items are for video device only.
  2. The field items are for DRM and video device only.
