Pre-process Device Parameter
The following code block shows the data structure for the pre-process device parameter structure.
typedef struct _ST_PP_DEV_PARAM {
    STF_U32 u32PixelFormat;
} ST_PP_DEV_PARAM, *PST_PP_DEV_PARAM;
Table 1. Pre-process Device Parameter Field Description
Field Description
u32PixelFormat The pixel format
