DRM Device Parameter
The following code block shows the data structure for the DRM device parameter structure.
typedef struct _ST_DRM_DEV_PARAM {
    STF_U16 u16Width;
    STF_U16 u16Height;
    STF_U32 u32PixelFormat;
    STF_U32 u32BufCount;
    STF_INT nConnectorId;
    ST_DRM_DEV *pstDrmDevHead;
} ST_DRM_DEV_PARAM, *PST_DRM_DEV_PARAM;
Table 1. DRM Device Parameter Field Description
Field Description
u16Width The width of DRM buffer
u16Height The height of DRM buffer
u32PixelFormat The pixel format
u32BufCount Indicate the amount of DRM buffers
nConnectorId The connector id of DRM device
pstDrmDevHead Point to the head of the DRM device list
