Pre-process Video Device Mode
The following code block shows the data structure for the pre-process video device mode structure.
typedef struct _ST_PP_VDO_MODE {
    EN_PXL_FMT enPxlFmt;
    STF_UINT uiHeight;
    STF_UINT uiWidth;
    STF_UINT uiAddr;
} ST_PP_VDO_MODE, *PST_PP_VDO_MODE;
Table 1. Pre-process Video Device Mode Field Description
Field Description
enPxlFmt Pixel format
uiHeight Image Height
uiWidth Image width
uiAddr Buffer address
