Video Device Pointer Table
The following code block shows the data structure for the video device pointer table structure.
typedef struct _ST_VDEV_PTR_TBL {
    STF_U32 u32Count;
    ST_CI_DEVICE *pstVDev[EN_ISP_PORT_IDX_MAX + 1];
} ST_VDEV_PTR_TBL, *PST_VDEV_PTR_TBL;
Table 1. Video Device Pointer Table Field Description
Field Description
u32Count Indicate the amount of devices in this table
pstVDev Device pointer structure array
