DRM Buffer
The following code block shows the data structure for the DRM buffer structure.
typedef struct _ST_DRM_BUF {
STF_U32 u32Pitch;
STF_U32 u32Size;
STF_U32 u32FbId;
STF_INT nDmaBufFd; // Used for DMA_BUF
STF_INT nBufObjHandle;
STF_U8 *pu8Buf;
} ST_DRM_BUF, *PST_DRM_BUF;
| Field | Description |
| u32Pitch | The pitch of dumb buffer |
| u32Size | Dumb buffer size |
| u32FbId | The index of frame buffer |
| nDmaBufFd | The file descriptor for the DMA buffer |
| nBufObjHandle | The object handle of the dumb buffer |
| pu8Buf | The dumb buffer pointer |
