Using SSH over Ethernet as Root Account
After the new system is installed, the rejected connection denial appears when you try to log on to the Ubuntu Linux server as a root user. Here is the example information:
$ ssh root@192.168.120.41
ssh: connect to host 192.168.120.41 port 22: Connection refused
To enable SSH root login, perform the following steps:
  1. Run the following command to configure the SSH server:
    echo 'PermitRootLogin=yes'  | sudo tee -a /etc/ssh/sshd_config
  2. Restart the SSH server:
    sudo systemctl restart ssh.service
    You will be able to use SSH login using the root account. The following output indicates the login is successful:
    Example Output:
    $ ssh root@192.168.120.79
    The authenticity of host '192.168.120.79 (192.168.120.79)' can't be established.
    ECDSA key fingerprint is SHA256:WhxBNiLBOS3J0IzNyBBuOeoNDRVqVQXfxC4MjZ7tbbo.
    Are you sure you want to continue connecting (yes/no)? yes
    Warning: Permanently added '192.168.120.79' (ECDSA) to the list of known hosts.
    root@192.168.120.79's password:
    Welcome to Ubuntu 24.04.3 LTS (GNU/Linux 6.12.5-starfive riscv64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/pro
     System information as of Wed Oct 15 06:46:40 UTC 2025
      System load:  3.19              Temperature:           49.4 C
      Usage of /:   9.0% of 51.15GB   Processes:             226
      Memory usage: 13%               Users logged in:       1
      Swap usage:   0%                IPv4 address for eth0: 192.168.120.79
    Expanded Security Maintenance for Applications is not enabled.
    23 updates can be applied immediately.
    16 of these updates are standard security updates.
    To see these additional updates run: apt list --upgradable
    Enable ESM Apps to receive additional future security updates.
    See https://ubuntu.com/esm or run: sudo pro status
    The list of available updates is more than a week old.
    To check for new updates run: sudo apt update
    root@starfive:~#
  3. Login as root account using SSH as described in Using SSH over Ethernet.
