Using SSH over Ethernet
After installing Debian, you can log in to Debian OS on VisionFive 2 through an SSH connection over the local network.
- Insert the micro-SD card with the Debian image into the VisionFive 2 and power on.
- Connect one end of an Ethernet cable to the RJ45 connector on the VisionFive 2 and the other end of the cable to a router.
- After a successful Ethernet connection, your router will assign an IP address to the VisionFive 2 and it will be connected to the Internet.
- Continue the steps according to your OS:
