Multiple Screens
The Buildroot SDK Weston supports multi-screen with the same or different display and hot-plug functions.
You can differentiate screens based on the name of DRM (obtained through Weston start-up log or /sys/class/drm/card0-<name>).
You can configure the settings in environment variables.
The following list provides examples for different scenarios.
  • Specify HDMI-A-1 as the main display:
    export WESTON_DRM_PRIMARY=HDMI-A-1
  • In mirror mode (multi-screen with the same display), if you skip this environment variable, the system will show different displays:
    export WESTON_DRM_MIRROR=1
  • In mirror mode, scaling maintains the aspect ratio. If you skip this environment variable, the system will show forced full-screen:
    export WESTON_DRM_KEEP_RATIO=1
  • Turn off the built-in monitor automatically when an external monitor is connected:
    export WESTON_DRM_PREFER_EXTERNAL=1
  • When an external monitor is connected, keep the first external monitor as the main display by default:
    export WESTON_DRM_PREFER_EXTERNAL_DUAL=1
When the VOP hardware doesn't support scaling, it would try to use StarFive RGA 2D acceleration.
It also supports disabling the specified screen individually in the output section of weston.ini.
# /etc/xdg/weston/weston.ini
[output]
name=LVDS-1
mode=off
# off|current|preferred|<WIDTHxHEIGHT@RATE>
