Using SSH over Ethernet
After installing Ubuntu, you can log in to Ubuntu OS on VisionFive 2 Lite through an SSH connection over the local network.
- Prepare a VisionFive 2 Lite with Ubuntu image and power on.
- Connect one end of an Ethernet cable to the RJ45 connector on the VisionFive 2 Lite and the other end of the cable to a router.
- After a successful Ethernet connection, your router will assign an IP address to the VisionFive 2 Lite and it will be connected to the Internet.
- Continue the steps according to your OS:
