STFLIB_ISP_GetControl
Get a specific control handle from the ISP context.
STFLIB_ISP_GetControl(
    STF_VOID *pIspCtx,
    EN_CONTROL_ID enControlId
Table 1. STFLIB_ISP_GetControl Parameter Description
enControlId Control ID Input
Table 2. STFLIB_ISP_GetControl Return Description
Return Description
STF_VOID * Control handle
