STFLIB_ISP_GetModuleRdmaBuf
Get a specific module Rdma buffer form the ISP context.
STFLIB_ISP_GetModuleRdmaBuf(
    STF_VOID *pIspCtx,
    EN_MODULE_ID enModuleId
Table 1. STFLIB_ISP_GetModuleRdmaBuf Parameter Description
enModuleId Module ID Input
Table 2. STFLIB_ISP_GetModuleRdmaBuf Return Description
Return Description
STF_VOID * Rdma buffer pointer
