STFLIB_ISP_GetModuleName
Get a specific module name form the ISP context.
STFLIB_ISP_GetModuleName(
    STF_VOID *pIspCtx,
    EN_MODULE_ID enModuleId
Table 1. STFLIB_ISP_GetModuleName Parameter Description
enModuleId Module ID Input
Table 2. STFLIB_ISP_GetModuleName Return Description
Return Description
STF_VOID * Module handle
