STFLIB_ISP_GetModuleRdma
Get a specific module Rdma form the ISP context.
STFLIB_ISP_GetModuleRdma(
    STF_VOID *pIspCtx,
    EN_MODULE_ID enModuleId
Table 1. STFLIB_ISP_GetModuleRdma Parameter Description
enModuleId Module ID Input
Table 2. STFLIB_ISP_GetModuleRdma Return Description
Return Description
STF_VOID * Rdma handle
