STFLIB_ISP_PIPELINE_StructUninitialize
Free all of allocated resource from the pipeline.
STFLIB_ISP_PIPELINE_StructUninitialize(
    ST_PIPELINE *pstPipeline
Table 1. TFLIB_ISP_PIPELINE_StructUninitialize Parameter Description
pstPipeline Pipeline handle Input
Table 2. TFLIB_ISP_PIPELINE_StructUninitialize Return Description
Return Description
0 Success
Other values Failure
The file libCI_User.a is required for using this API.
