STFLIB_ISP_GetControlName
Get a specific control name form the ISP context.
STFLIB_ISP_GetControlName(
    STF_VOID *pIspCtx,
    EN_CONTROL_ID enControlId
Table 1. STFLIB_ISP_GetControlName Parameter Description
enControlId Control ID Input
Table 2. STFLIB_ISP_GetControlName Return Description
Return Description
STF_VOID * Control name
