STFLIB_ISP_IqTuningDebugInfoEnable
Enable or disable debug information print for the IQ tuning command.
STFLIB_ISP_IqTuningDebugInfoEnable(
    STF_VOID *pIspCtx,
    STF_BOOL8 bEnable
Table 1. STFLIB_ISP_IqTuningDebugInfoEnable Parameter Description
bEnable Enable/Disable Input
Table 2. STFLIB_ISP_IqTuningDebugInfoEnable Return Description
Return Description
0 Success
Other values Failure
