STFLIB_ISP_GetModuleIspRdma
Get a specific module IspRdma form the ISP context.
STFLIB_ISP_GetModuleIspRdma(
STF_VOID *pIspCtx,
EN_MODULE_ID enModuleId
Parameter | Description | Input/Output |
pIspCtx | ISP context handle | Input |
enModuleId | Module ID | Input |
Return | Description |
STF_VOID * | IspRdma handle |
