STFLIB_ISP_GetVideoDevice
Get a specific video device handle from the ISP context.
STFLIB_ISP_GetVideoDevice(
STF_VOID *pIspCtx,
EN_ISP_PORT_ID enIspPortId
| pIspCtx | ISP context handle | Input |
| enIspPortId | Video device ID | Input |
| Return | Description |
| STF_S8 | Return positive identifier or negative number if sensor cannot be found |
