STFLIB_ISP_GetModuleParam
Get a specific module parameter from the ISP context.
STFLIB_ISP_GetModuleParam(
    STF_VOID *pIspCtx,
    EN_MODULE_ID enModuleId
Table 1. STFLIB_ISP_GetModuleParam Parameter Description
enModuleId Module ID Input
Table 2. STFLIB_ISP_GetModuleParam Return Description
Return Description
STF_VOID * Parameters handle
