STFLIB_ISP_GetControlParam
Get a specific control parameter from the ISP context.
STFLIB_ISP_GetControlParam(
    STF_VOID *pIspCtx,
    EN_CONTROL_ID enControlId
Table 1. STFLIB_ISP_GetControlParam Parameter Description
enControlId Control ID Input
Table 2. STFLIB_ISP_GetControlParam Return Description
Return Description
STF_VOID * Parameters handle
