STFLIB_ISP_GetVideoDevice2
Get a specific video device handle from the ISP context.
STFLIB_ISP_GetVideoDevice2(
    STF_VOID *pIspCtx,
    CI_BUFFTYPE enBufferType
Table 1. STFLIB_ISP_GetVideoDevice2 Parameter Description
enBufferType Video device buffer type (CI_TYPE_UO … CI_TYPE_Y_HIST) Input
Table 2. STFLIB_ISP_GetVideoDevice2 Return Description
Return Description
STF_VOID * Video device handle
