GetExposure
Query the sensor for the current exposure period.
GetExposure(
SENSOR_HANDLE *pstHandle,
STF_U32 *pu32Exposure,
STF_U8 u8Context
| pu32Exposure | Exposure time value | Output |
| u8Context | Sensor context. No longer in use | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
