SetFPS
Set the FPS value in the sensor.
SetFPS(
SENSOR_HANDLE *pstHandle,
STF_DOUBLE dFps
| dFps | FPS value | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
