GetExposureRange
Get the range of exposures the sensor can use.
GetExposureRange(
SENSOR_HANDLE *pstHandle,
STF_U32 *pu32Min,
STF_U32 *pu32Max,
STF_U8 *pu8Contexts
| pu32Min | Minimum exposure time value | Output |
| pu32Max | Maximum exposure time | Output |
| u8Context | Sensor context. No longer in use | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
