SetExposure
Set the sensor to the requested exposure period.
SetExposure(
SENSOR_HANDLE *pstHandle,
STF_U32 u32Exposure,
STF_U8 u8Context
| u32Exposure | Exposure time value | Output |
| u8Context | Sensor context. No longer in use | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
