GetMode
Fill in a structure detailing the modes supported by the sensor.
GetMode(
SENSOR_HANDLE *pstHandle,
STF_U8 u8ModeIdx,
SENSOR_MODE *pstModes
| u8ModeIdx | Sensor mode index | Input |
| pstModes | Sensor mode information | Output |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
