GetInfo
Release and de-initialize the sensor.
GetInfo(
SENSOR_HANDLE *pstHandle,
SENSOR_INFO *pstInfo
| pstInfo | Sensor information handle | Output |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
