GetState
Get the current state of the sensor.
GetState(
SENSOR_HANDLE *pstHandle,
SENSOR_STATUS *pstStatus
| pstStatus | Sensor state | Output |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
