GetInterfaceInfo
Get the sensor's connection data bus and I2C hardware information.
GetInterfaceInfo(
SENSOR_HANDLE *pstHandle,
SENSOR_INTFC *pstInterface
| pstInterface | Sensor interface handle | Output |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
