GetModeIdx
Get the sensor mode index.
GetModeIdx(
SENSOR_HANDLE *pstHandle,
STF_U16 u16Width,
STF_U16 u16Height
| u16Width | Image width | Input |
| u16Height | Image height | Input |
| Return | Description |
| STF_S8 | Sensor mode index |
None
