SetMode
Set the sensor mode.
SetMode(
SENSOR_HANDLE *pstHandle,
STF_U8 u8ModeIdx,
STF_U8 u8Flipping
| u8ModeIdx | Sensor mode index | Input |
| u8Flipping | Flip and mirror information | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
