GetFixedFPS
Get the fixed FPS value in the sensor.
GetFixedFPS(
SENSOR_HANDLE *pstHandle,
STF_U16 *pu16FixedFps
| pu16FixedFps | Fixed FPS value | Output |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
