SetGain
Set the current gain to the sensor.
SetGain(
SENSOR_HANDLE *pstHandle,
STF_DOUBLE dGain,
STF_U8 u8Context
| dGain | Gain value | Input |
| u8Context | Sensor context. No longer in use | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
